3D Scanning your way to a New Bumper
Pickens
So a few of you expressed interest on how I design my custom bumpers. This process will let y'all scan anything into the computer with reasonable accuracy (I get <.10" error over the width of a truck), and with some practice in 3D design, will allow y'all to design what ever you dream up. Yes, it does take a CNC table to turn a lot of those ideas into reality but SOME fabrication shops love to see people build their own stuff and will cut parts for people who want to fabricate at home.
Please take note, that we are pushing the technology here, so play with it a little, and also having a beefy CAD computer is a necessity, but if you're planning on computer designing, this shouldn't be a surprise. And I don't want to scare anybody off, but it does take a good bit of understanding of computers and 3D design to get this to work well. Rest assure, the Internet knows all, and you might just have to do a little extra reading to get it going.
1. Strip the bumpers off the truck. You'll want to have good view of the mounting points you want to use.
2. Here's the magic. You'll want to find one of the original xbox 360 Kinect sensors (360 kinect sensors have a aux power supply which is necessary). These pack a decently high quality IR matrix projector and camera.
3. This is a big step here: With a windows computer, install the drivers and programs in the specified order. This youtube video does a good job documenting the steps, and the links along with a written guide is in the description of the video.
4. After you get all the drivers installed you need to download a scanning program and install it. I use ReconstructMe its very basic and will allow you to scan most stuff.
5. Plug in the kinect into wall and into the computer's USB. Start program and adjust your scan envelope and scan away.
Remember when I said you need to play with it, well this is where you'll be playing :p. It takes some getting used to to get a good scan, things I've learned: It doesn't like shiny objects or glass, so dirty trucks are best, you might have to cover chrome up to get a good scan. Don't go back and forth, just take one slow pass.
6. After you get a good scan, Save it as a STL.
7. Once you have your surface file you can load it into your favorite modeling program and design away!
Here's an example of the Chase Rack for our Shop Truck:
And voila:
Good Luck!! :rockon:
1/10 inch is pretty low accuracy, but I guess the hardware is really cheap. I'm used to blue light scanners and things like that with really high accuracy. I'm not using them to make stuff at home though.. :D
There are really easy ways to get around the reflection problems with glass and chrome; there are many products that you can apply in a mist coat from a rattle can and are water soluble so they wash right off. With such low accuracy, you don't have to worry about surface roughness or splotchiness from an anti-refl coating.
As long as you know your accuracy, or lack there of, and to how far off you are, it should be pretty simple to compensate depending on the part you are building.
Cool stuff. Wish I had the time to get it set up and play some.
I'm debating playing around with this, because I have a Kinect sensor that hasn't been used in almost 10 years (the XBOX hasn't been used in that long either. Not really a gaming person).
Can you give us an example of 1/10" in accuracy? If it's gap between plate, a good welder can fill that very easily.
For example: if you scan the frame it might measure 46" wide in real life, while the 3d image you generated might say 46.1". So....... yeah it works just fine for my needs. :)
The accuracy is a lot more critical for surfaces than with discrete points, as you can adjust easier for discrete points than for surfaces that don't align or interfere because of accuracy problems. I don't know if that 1/10 inch accuracy is +/-0.050 or +/-0.1 inch
