Tube buggy
98yota
Statesville
Tube buggy rock crawler I have owned for a few years. Older build but super capable and very stable. 108” wheel base, boat sided with uhmw and aluminum skins, fiberglass hood and grill. This was set up for a shorter guy I’m 5-10” and it fits me well I’m guessing a 6’ person would be the max for current seat arrangement. Sbc 350 on propane, turbo 400 w/ art carr shifter, Dana 300 twin stick. Dana 60 front axle w/ Yukon shafts and ctm joints, east coast drive slugs, trussed and link with air bumps. 14 bolt rear full float disk brake rear. Wilwood 1” bore single pedals for front and rear for cutting, full hydro single ended, newer Corbeau seats and prp 4 points(I do have the 5 point just never mounted). 17” racelines w/ 43” tsl stickies (2022). Fox coilovers front and rear, wide open design lower links. I will include a 6.0 ls engine that needs gone through.
18.5 k cash on the 43 sx’s or 16.5 on the sticky treps. Cash is king not to interested in trades at this time and not pushed to sell. Full transparency, It could use some fresh paint on the tubing, the oil gauge in the dash isn’t working I have another attached, rear pinion has some play and pinion seal is leaking.
Located in Statesville Nc I do have a full size spare pitbull rocker, extra links, air bumps, rear driveshaft, spare propane tanks (a few need new pickup tubes ,recertified ) etc to go with it. If you need more pictures or videos I can get them.
It is currently on 40” sticky treps and steel beadlocks and I would sell it for 16.5. It does come with a spare sticky trep and steel wheel
