SciomSyzygy
- Jul 29, 2024
- Valdosta
Destroyed torque converter in my buggy. Had transmission rebuilt and wanted a higher stall. Used a 6 cylinder converter. It’s still too tight. Engine pushes thru the brakes when I’m on some rocks trying to crawl back and forth. This is compounded by engine computer that won’t let it idle slow under load so I have to use neutral a lot and bump reverse or drive. I called TCI for advice for a 2000 stall. I now have a 1700 stall. They recommended a 2200 to 2400. Book calls it 1000 over stock. Wouldn’t that be 2500? It’s lot of work changing it out so I want to get it right. Engine is crate 502 with turbo 400,Atlas 3:8,diffs are 5:13 ,43” tires on 3800 lbs. I got enough motor that I should not have to be reving high but I want it to be smoother.
