06f350 srw will 16.5 steel or aluminum alloys fit
zombhntr
powered by hate and dinosaurs
bunnlevel,nc
So I need some help has anyone put 16.5 rims on a 06 or newer superduty I'm looking to put steel or alum 16.5 so I can run military 37s
does anyone make a 16.5 in the SD metric lug pattern?
yep
I've seen guys running SD axles with 16.5 rims and if ur running h1s you can have any pattern you want, the reason I don't know if can run 16.5 is I think the brakes got bigger in 05
I run the 16.5 Mickey Thompson Classic II's on my Excursion. Military tires don't really last that long. The 16.5 Rims are hard to find and Most companies have Quit makin them. I have one that cracked and I needed a replacement for it and couldn't find one. So if you go this way you will be limited.
