sharksanddanger
- Apr 18, 2005
- Reidsville
What would you choose? What are the main differences? 10.25 full floater? Availabilties for lockers? Thanks for the input!
14bolt which is stronger than a 60 but not a 70 and with less gearing and locker options plus you gotta shave the hell out of it for ground clearance.
10.25, 60 or 70 rear What would you use....
read the post biotch!!! 5.38s are available but are not strong... they are easily breakable and that is the last thing I need. Please no more about 14blts in this thread! It is not an option...I vote save some money and go with a 14 bolt. The D70U has better clearance but you really can't shave as much off of as you can a 14b. I think all the engineering that went into 14 bolts is just cool... side adjusters so you don't have to use shims when setting up gears, removable pinion housing, pinion support bearing, two piece carrier, the list goes on. If you do get the D70 make sure you get the right one, some are 23 spline and are impossible to find aftermarket gears or lockers for.
If you're worried about gear selection I think 5.38's are out now, or will be soon. Or just put some reduction gears in the transfer case and call it good.
There's little appreciable difference between 5.13s and 5.38s. Not enough of one to be the deciding factor in a build. If you're worried about whether you spin 2400rpm at 65 or 2500rpm, then possibly.
You said the "last thing you need" is a broken pinion.... so the D60 and D70 and 10.25 are all out. Looks like you're shopping for an Eaton, 14 bolt, D80 or Rockwell.
Thanks for the people who have given quality opinions...
quality opinions. I didnt want to hear about 14blts or I would have said 10.25s, 60, 70 or 14BLTQuality opinions? or told you what you wanted to hear ?
thought they offered advise for and against, and offered up an alternative, and this isn't quality ?
guess I missed something.
