MR. GADGET
- Apr 5, 2005
- Raleigh NC
To start I'm looking to put 12v outputs on the front and rear of the Dodge tow rig for the warn 8000 multi mount and got to thinking about using the quick connects for the Ready Welder II as 12 volt for light work then when needed hook it up for 24v to for heavy steel.
What I was thinking was to take the 12v truck output (+) hook it to a (-) on a battery setting on the ground (extra battery I carry) and then the (+) from the battery (on the ground) to the welder and the (-) from the truck to the welder to make 24v.
I know it will be 24 v and run the welder but the question is if that will do anything to the truck electric system? It should be 12v at each battery.
Any help.
Jon
Any help.
Jon
