14 bolt FF or SF
marcusicp
Member
Tobaccoville
What is the beter version the 14 bolt FF or SF? Also how can you tell without opening it up if it is a FF or SF? I'm shopping around for one now and want to make sure i get the right suff.
Thanks!
FF means full-floating. SF means semi-floating. That's referring to the axle shaft. A FF axle will have a hub with two bearings that the tire bolts to, just like a front axle. The hub is completely separate from the axle shaft.
FF rears are inherently stronger than SF, since a SF shaft has to both hold the weight of the vehicle and transmit torque to the tire. A FF shaft just transmits torque. The weight is transferred directly from the tire, to the hub, through the bearings to the axle housing.
Where the 14 bolt is concerned, the 14FF and 14SF aren't at all the same. Some axles (Dana 60, 10.25, etc) have both FF and SF versions. The 14 bolt is only called that because it has 14 bolts on the cover. It just happens that Chevy makes two axles with 14 bolts on the cover. Eh?
Long story short, find a picture of a 14FF diff cover, so you know what they look like. Note also that the 14FF has a removeable pinion support (like a 9"), so if you look at the front of the housing, there should be six bolts around the pinion yoke.
Ah, fawk it.... just read this:
http://www.pirate4x4.com/tech/billavista/14b_bible/ it's got plenty of pictures, too.
what are you building ?
some people running 3/4ton stuff run the semi floater. It's a lot lighter than the FF axle, has nice 12" drums out back, comes in 6 lug and 8 lug. Got nice large axle shafts.. people call it a 12 bolt axle on steroids...
Thanks for the good replys!
Im building a k5 frame with a truck body. Has a very mild 350 now but my friend has a 468 with lots o horsepower lol that i will be swaping soon. Also I will end up running 53" XZL or 44-49ish bogger, Irok, tsl, SX....ect
I would like to go with rocks but the top load makes it very hard to get a lowish center of gravity. I under stand that no mater what it is going to be tall, but with 1 tons I should be able to keep it as low as posible.
Is there a way to keep it kind of low with the rocks? What about unimogs?
csudman said:
14 bolt, but you will probably need rocks if your goin that big.
