1977 CJ-7
ncbeachjeep
Wilmington
I backed out of my garage today and when I started to go forward I hear a pop noise (or like something metallic hit something) then when I kept going it would make the same noise a few more times until I got going then would stop, but everytime I start back up it does it again. It sounds like it is coming from right under me or perhaps rear end? any ideas?
Do you still have 2 piece rear axles? If so you may have spun a hub. Have you /do you check the torque on the rear axle nut? You should do it yearly if you run 2 piece axles.
Qtrac?
