Bocephusfan New Member Joined Jan 30, 2011 Location shelby, NC Jan 30, 2011 #1 thinking about doing a conversion What year models will fit on a 1983 F100 2wd such as front axle, transmission, transfercase.
Hurdt299 Well-Known Member Joined Nov 13, 2006 Location Asheville, NC Jan 30, 2011 #2 The easiest axle to use would be a 79 and older F-150 dana 44. It uses coil springs and trailing arms just like the 2wd suspension you have now.
doc Odd Member Joined Mar 20, 2005 Location Southmont Jan 30, 2011 #4 '80-'96 F-100/150 or Bronco will bolt up - more or less......but it will be TTB & not SAS
doc Odd Member Joined Mar 20, 2005 Location Southmont Jan 31, 2011 #6 Twin Traction Beam - a split dana 44 - sort-of..... SAS - Solid Axle Swap
