1988 toyota 4x4
jmorg18
glenwood
can any one tell me what kind of rim fit a 1988 Toyota 4x4 im new to this stuff and just got this truck and want to put a lift kit on it and some wheels and tires and have no clue i dont want to spend a lot of money bc its just a lil toy for now maybe later ill upgrade
Thanks Newbie
Pretty much any six lug wheel out there. They fit chevys, Nissans, Toyotas etc. I just put a set of rims on my DD '97 4runner for like $400 and change. Outlaw style in 15x8.
hey can anyone tell me how to replace the bearings on the rear axle i got the bearings an seals just gotta get them on i had had the rear end on the right side heat up cause bearings locked an melted seals which threw gear oil everywhere an now i cant get the bearing back on an back on the drum an back in need help
Huh? If you're talking about the bearings on the rear axle shafts, they are pressed on. There is a special tool for this. However, if you don't have access to this tool, I've seen a video on the web of a guy that takes a piece of Masonite, puts it on the concrete driveway and slams the axle spline side down on the Masonite. The weight of the brakes etc pushes the bearing off the axle. Then he uses a brass punch to reinstall the bearing. Remember to put the seal on first or you'll be doing it again.
