1993 Toyota Pick Up SAS $3000
Discussion in 'Vehicles For Sale' started by ProbablyBroke, Jul 26, 2019.
  1. ProbablyBroke
    ProbablyBroke does not torque to spec
    Nov 7, 2012
    Charlotte
    IMG_5070.JPG IMG_5073.JPG IMG_5074.JPG IMG_5075.JPG IMG_5077.JPG IMG_5079.JPG IMG_5081.JPG IMG_5083.JPG IMG_5084.JPG IMG_5086.JPG IMG_5087.JPG
    I'm selling one of my toyotas. I have a title in the previous owners name, and his contact info, but had no intentions of titling or registering the vehicle.
    22re
    5 speed
    new Exedy clutch (oversized)
    BudBuilt single case cross member new
    4.30 gears front/rear both w/ lock rites
    Square tube front drive shaft
    Treated lumber flatbed with brake lights
    36x12.5x15 TSL SX 50%
    aluminum bullethole wheels
    2.28 transfer case gears
    9000 winch with in cab control
    Trail gear weld on winch plate
    Sky offroad front spring hanger (boxed)
    Optima red top battery
    Trail gear high steer
    27 spline chromoly front axle shafts
    Trail gear 5" front springs
    Chevy rears
    Greasable shackles
    JVC stereo with aux
    Sunpro tach
    Truck starts and runs well. The motor does smoke some. I'm thinking it's valve seals because of how long it sat before I got it. Transmission input shaft bearing is a little noisy. Windshield is cracked.
    3000$ or trade for an ATV
    Truck is located near Ahoskie, NC
    If you want it cheaper, I can take the axle shafts and winch, possibly swap tires to 37" Iroks
    I could deliver to raleigh area for fuel.
    704-277-9946
    72Rockcruiser and doc like this.
  2. Jamie22
    Jamie22 Active Member
    Jan 21, 2010
    bluefield, wv
    Best money on it ?
  3. ProbablyBroke
    Nov 7, 2012
    Charlotte
    4.30 locked front and rear
  4. K9guy
    K9guy Well-Known Member
    Oct 21, 2006
    Beckley WV
    Jamie you need this, my wife said not enough room or I would be wheeling this.
    ProbablyBroke likes this.
  5. ProbablyBroke
    Nov 7, 2012
    Charlotte
    Someone needs to buy it before I trade it for an atv this weekend.
    I forgot. It has diff stud eliminators. And 4 piston disc brakes with vented rotors in the front. New seals trail gear front axle seals. New rear axle seal. Stainless Braided brake line.
  6. ProbablyBroke
    Nov 7, 2012
    Charlotte
    Warn hubs, triple drilled t case flanges, detent ball removed for 2wd low. Someone needs a budget crawler.
  7. K9guy
    Oct 21, 2006
    Beckley WV
    1700 I’m in lol
  8. Jamie22
    Jan 21, 2010
    bluefield, wv
    Yea I want it for the farm. If it had 4 seats I'd definitely would already owned it
  9. Jamie22
    Jan 21, 2010
    bluefield, wv
    I bid 1750 lol
  10. ProbablyBroke
    Nov 7, 2012
    Charlotte
    I'll take 1500... from each of you. Y'all figure out the custody rights.
  11. K9guy
    Oct 21, 2006
    Beckley WV
  12. Jamie22
    Jan 21, 2010
    bluefield, wv
    Lmao
Share This Page
