Papa_Jon
non speller
- Jul 27, 2007
- China Grove
Do the 99 tj have a option when you put in reverse the driving lights/fog lights come on, or is this thing got a short?
N0t tail lights. Front fog lights ..Not sure. Basically what is happening is when you engage reverse it turns on the rev lights and it is also somehow tied in to the tail/running lights. This normally happens when you have a short between circuit. Try disconnecting one taillight then the other. By doing this you will start to eliminate things from the possible causes.
Drove her to work so if slow Ill check. wire up front led yesterday got them to blink ,NOTICE THEY dont blink on inside when head lights on , the arrows stay lite up lol ,The front fog lights are probably getting power through a rear tail light that has an internal short or is incorrectly wired. That's the most likely cause.
If not that, power for the reverse lights comes up the engine harness from the trans to the connectors at the top of the firewall, then connects to the chassis harness and runs to the rear lights via the driver's side frame rail. If there's a short in the harness, it would probably be there at the firewall.
But my money is on tail lights.
Well went to look at it blinkers blink with KOEOff but when KOEOn they don't work ughhhh. guess I will start over pull everything and do one by oneDrove her to work so if slow Ill check. wire up front led yesterday got them to blink ,NOTICE THEY dont blink on inside when head lights on , the arrows stay lite up lol ,
rear been there , front had the little 1/2 blinkers since i did flat fenders . I just noticed the fog light issues last few weeks , yesterday I found some 2" round amber leds I had left from old project . So i installed them ..FYI done know what TJ grills are made of but it smoked a hole saw fastDid you just start on the LED swap? Did they work before correctly before this?
Glad you got it straightened out.got it figure out .... it was reverse lights where tied in to parking lights
