VortecJeep
Powered by Uranium-235
- Aug 24, 2005
- Concord, NC
Front Passenger window motor will not work. I took the door panel off, took out the bolts holding the motor to the door, and there is 1 end of the cable that is still attached at the window. Looks like I need to be able to remove the cable to replace the motor. Anybody had this problem? How do I get the cable off the window? It is hard to see inside the door, even with a mirror.
Prolly should have goten stitches. So watch out if you end up having to dissasemble yours. Reassemble was no easy feat either. Third hand would have been nice.
