tkeaton
Master Velocipede Alchemist
- Mar 20, 2005
- Chattanooga
how much should i expect to spend to have 220v run (welding purposes) here in raleigh, also, any electricians i should consider over others in the area? thanks guys
rockcity said:Also, it may be easier to use the existing outlet, just make an extension cord to reach where you need to go.
Rob
saf-t scissors said:Nah, I just made an extension cord with the dryer plug on one end and a welder socket on the other. Unplug the dryer, plug in the welder.
kilby said:You don't need to use a dryer plug for 220.
For your welder you probably only need a 20amp dedicated circuit (ie - ALL you will run off the circuit is the welder by itself). It took about 20 minutes to put mine in the wall. It's right under the panel in my shed. I just used about 3 feet of 10-3 wire, a 20a breaker, a pop-in wall box, and the cover & receptacle. It's a 20 amp version you can get a Lowe's or whatever.
This is the type of receptacle I use. My welder has a standard 3 prong plug, but some may have the cross plug which is why the 20a recept. has the hole w/ the extra shape on the left (whatever you call that). No reason for the different shaped plug... It's just to prevent you from plugging a dedicated 220 plug into a standard wall outlet, and blowing a breaker.
StudNuts said:the 220 that uses a standard 110 outlet is whats called a 220/110. Its 220v but uses a 110v socket. The only difference is its real low amperage. Normally it should just look like its winking so other normal 110 plugs couldnt be plugged into it.
kilby said:And, no, the shop vac doesn't suck my skin off.
