khwrx
- Dec 10, 2006
- lincolnton nc
ok i been chasing a no start problem with my 22r on propane. i currently have installed a msd 6a and msd wires. when i test my msd and coil the coil is sparking but the pickup in the distributor seem to be not switching like it should. i looked up the ohm spec on alldata and its says it should be between 130-180ohms and my reman distributor is at 250ohms. can someone test theirs to see what they read. do you think this maybe the reason its not starting ?
