I have an 86 Toyota Ext. Cab Truck with a 22RE with 155k. It runs but then stops after about 15 seconds. I changed the fuel pump relay and fuel filter. I hear the fuel pump cut in when the key is in the start position but not in the on position. The truck will continue to run if I bump the key to start which tells me the fuel pump is not continuing to run--I think. Any thoughts?
Brakes. My pedal was going straight to the floor with the truck on and off. I replaced the master cylinder and brake booster. Now the pedal has pressure with the truck off but not so much when the truck was running. I bled the master cylinder and brakes all the way around. What should I do now?
If anyone is around Raleigh and wouldn't mind lending a helping hand that would be awesome. I bought this project hoping to make a daily driver out of it and do some wheeling here and there. I have some wiring issues with the turn signals and reverse lights to.
