BrianGreen
SSG Brian Green
- Apr 5, 2008
- Kings Mountain
Is the bolt on the front of the crank right hand thread or left. I need to know before I put a cheater bar on it to break it loose. Thanks
You may not get the breaker bar to move it. I put my breaker bar on the frame rail and tapped the stater to break it free. Not for the weak of heart. But it worked real good. OH and remember to remove the wire from the coil to the distributer so it doenst fire and cause mayhem.
I hope you made that up, that is the most random thing i have ever heard and of course is also the most ridiculous.
Im still a bit confused here people you said pull an injector.....
im guessing you mean pull a plug, then the rope is wedged between the piston and the valve, Ya its certiantly a good idea to make sure the valves are closed. And 22's are interference motors.
