skyhighZJ
- May 31, 2012
- Aberdeen, NC.
1989 Toyota pickup
22RE 5 spd 4wd
Issue: when accelerating the truck is stumbling like a lack of power unless you put the pedal in the floorboard then it accelerated just fine with all the 87.9 horse-pressures it can muster. Idle is smooth and flawless. Maintains speed on flat road. As soon as you give it pedal it will start to hiccup and buck like it’s starving for fuel but max throttle and it smooths right our so I don’t think fuel is an issue.
Has new plugs, wires, cap, rotor.
New timing set, water pump, oil pump.
Replaced the manifold and exhaust cause it had a cracked manifold and the O2 sensor was froze into the mid pipe.
Startup and idle are perfect and smooth.
Revs up without load perfectly.
It’s an ‘89 so not like I can just plug it in. No CEL either.
Pretty lost cause it was running fine.
I did fill up with a bottle of Heet and premium today. No change after about 60 miles. Thinking TPS ???
22RE 5 spd 4wd
