- Mar 20, 2005
- Morganton NC
Has anyone here done this yet?
What I have so far:
231 case that has been split, cut, and piece welded in. (this does away with all the chain and front out put) with kit bolted up. I went ahead and upgraded to a 6 planetary gear set. Found it on E-bay for like $40 shipped(IIRC)
What I have yet to do(install)
Pull my stuff apart, mount 231 to T-176 adapter. Mount Dana 300 to the back of the 231.
I am gonna clock the 300 up, so along with making my shifters longer ( the 300 will be 8" further to the rear) I will have to do some bending to comply with the clocking.
make some linkage to work the 231
Shorten the rear drive shaft
lengthen the front drive shaft
make a mount for both the 231 and the 300
Make new skid
what this will net me is:
four ranges
1:1
2.72:1
4:1
6.72:1
I am currently at a 70:1 crawl ratio with my 4:1 in my Dana 300
Final crawl should be like 180-190:1
this should allow a little higher RPM's when crawling and a lot less stalling when I run RPM's low to go slower
Plan is to work on it this coming weekend with a good friend of mine. I will do my best to take some pics of the install
What I have so far:
Make new skid
four ranges
1:1
2.72:1
4:1
6.72:1
