282 mpg VW
vanguard
Apex, NC
This thing doesn't look half bad for a DD. I typically go 12-15 miles each way to work. A car like this would be perfect for that. It should cost $31k - $47k. That's too expensive for my tastes but the direction is encouraging. It's even a diesel for all you diesel fans.
http://www.treehugger.com/files/2008/07/vw-282-mpg-1-one-liter-car-production-2010.php
235mpg?, means it either has a super small tank and costs only $4 to fill her up, Or it has a normal sized tank, say 20 gallons, which should only take me 4,700 miles per tank. What if i need to go further? sure hope it comes with gerry cans...
With a 20 gallon tank most folks would have to polish their fuel...
Why can't manufacturers put this kind of technology in a more appealing body style? I would think it would sell pretty well in a Golf body. I know aerodynamics have a little to do with the gas mileage but at 80mph aerodynamics aren't a huge factor. Even if the mpg dropped to 150mpg it would still be a killer car. I would pay 40k for 150 mpg in a Golf. And really how safe can these tiny little cars be?
Whole vehicle only weigh 600 lbs.
Seriously doubt it's a 20 gal tank, seeing as how that would add what, 150 lbs or 25% to the weight. My bet is it's about 3 gal max.
Is this case, the shape is key - a major part of the economy is due to the crazy low coefficient of drag. Unfortunantely, acquiring this level of aerodynamics requires it to look like a damn bubble.
Dern physics ruins all the good aesthetics.
It could very easily be made to look less like a cell phone and still retain a very low coeffiecent of drag though. Think of this kind of technology slapped into something resembling the lines of a MX5 mazda or the audi tt or 350Z. Couldn't absolutely retain the 200+ mpg. But with the right construction, (keeping the wieght to a minimum) and some careful wind tunnel design taken into hand there's no reason a manufacturer can't put out a 125mpg ,give or take, decent looking subcompact car. I think the biggest issue when it comes to producing something with very high milage over here is wieght. The current crop of sub-compacts all wiegh as much or more than my '66 Mustang (2619lbs. with me in it and a full tank) and don't get too damn much more in the way of mpg. And alot of the wieght problem comes from the infatuation with power gizmos, and our strict safety regs. (not saying airbags and gps, and power everydamnthigns are bad, just heavy) My business partner had an '82 Honda Accord wagon that with a fuel leak at the back of the carb was getting over 40mpg, 99% of the cars that size today get less in the way of fuel economy, likewise I'm able to pull off 26-27mpg on a '66 mustang with a swapped in 5spd., and a .060 over 289 with alot of cam, and 11.5:1 compression. I think it's absolute crap that a new 'stang with all the technology put into it to get better milage, burn cleaner, and improve aerodynamics gets the same or worse mpg.
That sucks, I suppose they expect all drivers to be Jockeys. I weigh 150lbs. Lots of guys weigh around 200lbs. Thats 33%. That would be kind of like loading my jeep down with a 1500lb driver.
What happens if you leave the fuel in there all year.... wont it go stale?
