vatoy86
- Nov 19, 2007
- Bristol, VA
I’m finishing up my buggy build but I’m having trouble with my 97 2rz. Starts and idles fine but once it gets a little heat in it to go to open loop it goes all to heck. Idles rough, studders and back fires when reving up. O2 is reading lean and it’s over fueling (plugs are wet). Engine harness is factory and under dash harness was done by Toy only swaps. I’ve replaced dizzy cap, rotor, plugs, and wires. Mass air meter, TPS, water temp sender, crank position sensor, and O2s. Tried a different distributor and ignitor. Fuel pressure is good. Instead of throwing any more money at it with no success I figured I would ask and see if any of you guys have ever experienced anything like this and could offer advice. Thanks
