superpile
Probably running in circles
- Jan 17, 2006
- Asheville nc
I am running a motobilt tank and I’m running an external in line high pressure fuel pump. I keep getting whiffs of raw gas running from the exhaust. Should I put a adjustable fuel regulator on it to prevent over fueling Causing the to much fuel and the resulting smell? It runs fine but tries to stall after it warms up at idle. Smells rich when it starts up after it stalls. Figure I’ll bump up the idle to maybe fix the stall if needed but wanted some guidance on the fueling first. It is full hydro also for clarity but until it warms up it doesn’t have any stall issues. For additional info I rolled it and the tank pressurized while on the side flopping around. Guessing the roll over sealed it but the return line created a weird pressure build up maybe? Anyways suggestions?
