BIGWOODY
- Mar 21, 2005
- Thomasville
the throttle body on the LS1 is 3 1/2" in diameter. I need a piece of tubing , be it flexible or rigid , that turns 180 degrees so I can mount the mass air sensor and the air filter, there isn't enough room in front of the motor. Any ideas? I have about 4" or so between the motor and the fan on the radiator so if it were a rigid piece it would need to make a fairly tight bend.
