3.50 front and 3.55 rear
1% is no big deal, a variance in tire pressure front to back will create that much, especially when airing down. If you aren't going to drive on the street with it in 4wd I wouldn't worry about it. Offroad your tires will slip enough on dirt and loose rocks to negate most of any binding you will get. A lot of Nissan guys that keep their rears with the 4.636:1s are using Dana 44s with 4.56s and no ill effects. And the nissan 'case is chain driven.
Are you running another 9"? I should have a set of 9" 3.50s.
OnlyOneDR: yes I am running a 9in, if you have a set, I could definatly use some, I also see you are in raleigh, so I could come by and get them anytime
I will go by my storage unit and double-check the ratio tonight.
