35 spline install
upnover
Grumpy, decrepit Old Man
Moderator
Morganton NC
OK have not received my parts yet, just running all of this in my head.
I am told there is no issue using the stock spindles. What about the spindle bearings? Seems if the axle is larger diameter, then the spindle bearings would not work. Is there a different bearing? or? do you just not use the spindle bearing?
TIA
more less the 31splines neck down past that part of the stub. so even with the larger 35spline its the same size at that point..
I just pull off the brass inner washer/bushing, and the rubber seal thing and swapped them over..
