4.2 to 4.0 Engine Mounting Problem
wirsima
Raleigh NC
I'm repowering from a 1982 4.2L to a 2004 4.0L and al told that existing engine mounts should work. However, I seem to have a slight problems with them. My 1982 block on the driver side has the top boss that is not in the same vertical plane as the other 2 bottom bosses. The 2004 4.0L block has all 3 bosses on the same vertical plane. Do I have to machine the top boss down (about 1/2 to match my old block)? or is there another driver side mounting bracket I can use? Also, looks like I'll have to grind off a little bit of my passenger side bracket to clear a block rib.
if you use the 4.2 crank and rods and put them in the 4.0 you will have a 4.5 litre stroker. theres a few other small pieces .. but back to your question, it should mount right up. like the guy above me said try advance adaptors,
