98zjstroker
- Oct 14, 2009
- concord nc
So now is the time to install the motor but before I do I want to replace the original torque converter. I have the 42re transmission. There are a lot of options out there like lock-up converters and stall converter. Haven't found much on what people have been using for the jeep stroker.
Not sure if the stock converter is a lock-up but if not I was thinking about getting one that was to help reduce heat. Any thoughts on this for a stroker set-up? Is it best to go with a stock converter? I would assume not because of the HP and torque changes along with the use being more for power and offroad then what the original one was.
Second comes a stall converter. I know this depends on my RPM range, HP & torque, along with the weight of ZJ. Because of this I assume there is a range of differences between what people might be using so I am putting in specs of cam and estimates of HP and torque.
Cam lift int- .443, exh- .443
duration @ .050 .209 .213
duration .263 .267
RPM range per manufacture for the cam is 1000-5300RPMs
HP range from what I can find on a conservative estimate was 260hp and around 300ftlbs of torque. (unable to find out RPM at time of peak HP and torque) and a gross weight of 5300lbs
Without knowing RPMs at time of peak power is it possible to still get a torque converter that will work? And any ideas on where to go/order from for aftermarket torque converters?
duration .263 .267
