4 Gateway Buckshot Mudder Tires on Toyota Wheels, $600, Chesapeake, VA
Discussion in 'Tires & Wheels' started by midcoma, Jun 24, 2020.
  1. midcoma
    midcoma Active Member
    Jul 13, 2011
    Conover, NC; Jacksonville, NC
    Selling a set of 4 Gateway Buckshot Mudder tires mounted on factory Toyota split-3 aluminum wheels. I bought the tires to use on my 4Runner, but they'll be too small with upcoming suspension mods. I bought them used, but haven't used them myself. Tall and skinny, P78-16LT. Tires are bias ply.
    -32.5" tall and just under 9" wide (extra 2" at end of ruler in picture).
    -25/32 tread depth.
    -Tires are mounted with XtraSeal Bead Sealer on inner and outer tire beads to prevent slipping and ensure sealing at low pressures.
    -Each tire has 14oz of airsoft bbs inside for balancing.
    -Tires have been cut and siped for increased traction and better tread clearing. I added the cuts and sipes after I bought and mounted them.
    -New valve stems.
    -$600 for the set. Located in Chesapeake, VA. May be able to meet in NC depending on location.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Cuts & sipes
    [​IMG]
    [​IMG]
    [​IMG]
    justjeepin86 and 72Rockcruiser like this.
  2. sdbrassfield
    sdbrassfield Well-Known Member
    Jan 28, 2010
    Goldsboro
    What is the backspace on those?
  3. midcoma
    Jul 13, 2011
    Wheels are 16x7, 4.5" backspacing.
  4. rodney eppes
    rodney eppes Well-Known Member
    Feb 3, 2010
    Mt.Holly NC 28120
    Treadwise, there all but New! Don't know the date code, but I don't run that size anyway. Great Deal!
  5. midcoma
    Jul 13, 2011
    Tread is great and I put a lot of effort into the cuts and sipes to make them grip more. Kind of bummed I won't be trying them out. But I'm installing a LT kit so I'm moving up to 35s. That's the only reason these are for sale.
    rodney eppes likes this.
Share This Page
