4 link jacking
Chuckman
Huntersville
ok, so we copied (down to the inch) a clayton long arm 5" on a 2000 TJ, and so far have not installed the swaybars. we have a spool in a 9" rear. when we make a right turn, it jacks the left side up terribly (and vise-versa). is this indicative of the spool or the lift? can we control it with swaybars? whats up with this? :confused:
May be able to add some air to the tires on the street to help them slip easier too.
A spool with soft springs and shocks can do that. Looks like you have a lot of AS and little frame separation in that setup too which makes everything worse.
My ZJ with a spool and clayton's longarms does essentially the same thing on the street. It was worse before I got the front end geometry dialed in. Now, i just remember to do a somewhat 3-point-turn, or pull all the way through, when pulling into a parking spot to relieve the twist in the setup. I would imagine, with the shorter wheelbase of the Wrangler, the problem would be far more dramatic
