4l60e opoerating temp
Copasetic
Grovetown, GA
What's the normal operating temp for the 4l60e's? I just swapped in the new cluster and mine is running right below 150*. I'll see how it does towing Monday when I take the Sami to get the cage installed.
if that gauge is accurate then your good, anything below engine temp is good. the only way to verify if the gauge is correct is with a scanner and check actual trans temp sensor.
Good deal, thanks! What temp will it reach when should I start getting worried?
