Road_Warrior85
Member
- Jun 23, 2007
- Jacksonville, NC
Hello All,
Anybody remember me?
I am back from Iraq/Afghanistan (actually got to split my deployment between each location), and I FINALLY get my jeep back.
As some of you may remember, I had Brendan down at Performance Innovations swap my 4.0 for a 5.7 Hemi. As you also know, that didnt work out very well.
While I was deployed, I had another shop unf^ck Brendan's mess.
Below is the engine bay after Brendan finished.
Here is the engine bay after the second shop finished.
Not many major differences, but no more loose, random wires hanging around, and much cleaner set up.
No more check engine lights, no more 2" exhaust pipe (for a Hemi? come on, thats too small).
No more Limp mode in the transmission.
Its a perfect jeep......... Or so I though.
It only has about 2500 miles on it after the swap and my rear drive shaft is gone now.
The CV joint has been completely demolished.
Sadly, I ignored the extra vibrations coming from the jeep when I got home because it had been pretty much a year and a half since I had really driven it.
Then came the popping sounds.
Once I realized something was certainly wrong, I looked underneath and could see metal shavings coming out of the CV joint, and even some splatter marks where the U-Joints where slinging their grease out.
Brendan didn't do his measurements I guess, as the output of the T-case is not in the same position as before. As any of you can agree, just moving that mount 1 inch in any direction changes your angles quite a lot.
SO, now I am without a vehicle, and going on leave Wednesday. Too bad I have no drive shaft to actually get me to Alabama.
Monday morning a call to Tom Woods is in order I suppose.
Unless of course somebody knows a local shop that can build me a shaft that is just as good as the legendary T.W. shafts (that name is as common to drive shafts, as Chevy is to V8 Swaps)
