Lee
ECGS
- Mar 20, 2005
- Louisburg NC
I just recently replaced the engine in my 1995 Dodge Ram. Having a few problems with the new motor that are stumping me.
It runs like a scalded dog down low when on the throttle heavy, starts cutting out at around 4500 RPM's like it has hit the rev limmiter (rev limiter is at 5200)
-If you are easy on it around town it runs fine untill it goes into overdrive and then it will start missing
-Seems to be the most of the problems seem to come from light throttle under heavy load
-when you put the truck in reverse it surges and runs like ass, only in reverse, not in nuetral or in any forward gears.
-cruising out on the inerstate if you let it go into overdrive it surges and bucks like crazy occasionally, not always, but maybe every 2-3 miles.
Occassionly when pulling up to a light the RPM's will surge and then the truck will die
A little info
Motor built by Poteats Engines in Kannapolis NC
.030 over bore with magnum R/T cam and Heads
Mopar M1 Intake manifold
Ported throttle body
New ignition coil
New plug wires
new plugs
New ECT (temp sensor)
new distributor cap
new rotor
new fuel pump
Grounds are all good
Fuel Sync has been set to 0/1
Only code it has thrown was for the temp sensor and after replacement it has not thrown the code since (old sensor was broken)
Any idea's?
Gonna take a friend truck that is the same here pretty soon and try swapping some sensors and see if it makes any difference before I dump any more $$ into that does not seem to cure the problem
A little info
New ignition coil
New plug wires
new plugs
new distributor cap
new rotor
new fuel pump
Any idea's?
