SHINTON
- Mar 17, 2005
- Triad area of NC
I bought the 85 yota a couple months back now and took it to URE over Thxgiving weekend.
Went great...my only real issue is learning the tips/tricks to "rock crawling" with the 5 speed.
Up till now, I have only wheeled with automagics, so in those cases I would actually do alot of driving with left foot on brake, right foot on throttle.
Give it a bit of gas and use the brake to set/hold myself and control my crawl.
...so I sorta approached this the same way with the yota, but even with 5.29s / 4low / 1st gear you will still stall out sometimes....
So here is my dilemma.
I was in Kodak area doing the "standard" thing of hitting my clutch, putting in neutral/shifting over and then left foot on brake / right foot to feather the throttle and start up the truck again...
NOW...as you can imagine what also happened was me bouncing/rolling my way back off the rock/line/etc...
would get back up to the same place, stall out again, start over....finally get tired of this and just go around bypass.
I know I COULD have been more aggressive with the throttle.. but learning the rig / trying not to break and trying to learn how to CRAWL with this rig...
I KNOW the next time I go I will be running beadlocks...I was running 18psi in the BFG A/Ts, mostly worried/not sure how easy it was to lose a bead on a 15x10 rim (35x12.5 tire)....so the LOW PSI will help with my traction considerably
But...what/how are you guys crawling? Someone was telling me to go ahead and leave the yota in 1st gear and start it... Is that something I can do now (or wait until dual cases?)
How rough is that on the starter / battery / (other stuff?)
My other issue was no e-brake...not sure how I am gonna fix that (either have to find the right size cable/setup for 87ish/wider axle...OR put on a driveshaft ebrake?)
Finally...my "last" issue was not as much stopping power as I would prefer. I am guessing this will need to be solved via, bigger booster / and prob need to look at rear disk brakes?
At times / going downhill in 4low, etc / gravity pulling, I don't think the stock brakes could have STOPPED me unless I disengaged gear/clutch...
Ok...so now that I have proven myself a noob for wheeling with a manual... would love thoughts, tips and tricks... I know some guys swear by em.
What got me thinking about this again today, I was noticing in the video from waterfall/upnover thread/ the yota there had same issue, he would get set on the fall and then engine stall out...by the time he was ready to restart he had rolled all the way off the obstacle again?
