5 Speed conversion-88 Toy truck
SEAIRESCUE
SO Pines
In process of collecting parts for a A340H automatic to 5 speed conversion.
Can anyone tell me, knowing that the engine is a 3.0 V6:
1)-will automatic drive shafts work with 5 speed?
2)-will automatic cross member work with 5 speed?
3)-Wiring-I have the 5 speed computer, any thing else?
If you have done this before, I would appreciate any comments as well.
Thanks,
Wm :)
i did the swap on a 22re, and crossmember, drive shafts, and computer all worked fine.
I have heard people say that the auto computer gives you more power b/c it advances the timing to compensate for the auto, i don't know if it is true, pirate rumor, unconfirmed.
You have to short the nuetral safety switch together to complete the circuit and making it think it is in neutral all the time.
best thing to do is just measure your tranny's i have a five speed if you need one, and you will be able to tell if you can use crossmember and d-shafts.
