Chuckman
- Oct 9, 2005
- Huntersville
So I got the 6.0 swap done finally and I have just one issue. It wont take fuel over about 3K going down the road, but its not setting a code. I will call Jim on monday, but theres really nothing that I can do until then I guess. The only thing that is not 100% stock is the Novak VSS that they sell in one of their kits. I put it in the adapter between the 6.0/700R. It should be alright in there, but I dont know if its wired properly or gapped correctly- there wasnt any instructions since they took it from a kit, and dont normally sell the reluctor/pickup separately like they did for me. Anyway, it does stall when you stop short like its vss related- every now and then. I had Jim program it for a manual so that the 700r would be happy but it still needs a vss per Jim to get the mileage that I want. If the pcm still thinks its revving in park, would it taper off at 3k, like its doing now? The ls1 swap book just shows vss low and vss high on the schematic, so what is that? Is that just the 2 wires on the Novak pickup- are they omni-directional? Or do they have to be wired on way? The other thing I was going to do was check the pickup with a ohmeter - would that work- to see if the gap is correct? Man, this sucks cause I know tha Novak or Jims can field this one on the weekend. Any ideas? Otherwise cranks and runs REAL good. Just wont make power.
