Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
truck has sat since early Friday. it has been in the low 20s since then for highs. I'm thinking the cold is causing it to not shift and it to slip. it also will shutter once It finally does shift. only thing done to the transmission is a 6.0 cooler, I think I just undid where it ran threw the radiator. it seemed to drive fine Friday and the other times I drove it last week. the only time it acted like it was wanting to shift gears was when I was in 1st gear trying to get back home and the trans got up to about 145 degrees. it normally runs about 100-110 when not towing with the new cooler. it was also low added some and topped it back off but no change In the way it is acting.
