7.3 turbo diesel, OIL EVERYWHERE?
guffey24
Hendersonville, NC
never worked on a diesel, so I consider myself diesel dumb
Oil is pouring out from everywhere underneath
everything I read says
end cap o-ring in the high pressure oil pump, or bad high pressure line, or maybe a bad hpop
okay where in the hell is the hpop located, in the pan?, on the block?
have you checked your oil level check it to see if it smells like diesel fuel if so you might have a injector problem or a cracked head letting fuel fill up the crank case....
check the oil line to the turbo.
Location Type Width ID OD Vendor PartNumber Package AS568A Dash# Ford Part #
CCV Dog House Viton 1/8" 1.25" 1.5" Grainger 1KAF5 25/$10.43 -218
CPS Buna-N 3/32" 13/16" 1" McMaster-Carr 9555K26 25/$4.22 -117
CPS Viton 3/32" 13/16" 1" McMaster-Carr 1201T54 25/$9.56 -117
CPS Viton 3/32" 13/16" 1" Grainger 1KFL5 50/$9.17 -117
Fuel Drain Valve (these are the best) Fluoro-
silicone 1/8" 1/4" 1/2" Dieselorings.com
For use in extreme environments:
MS-25988/2 2/$6.00 -202
Fuel Drain Valve Viton 1/8" 1/4" 1/2" Grainger 1BYU7 25/$5.16 -202
Fuel Drain Valve Viton 1/8" 1/4" 1/2" McMaster-Carr 9464K118 25/$5.46/td> -202
Fuel Pressure Regulator Viton 3/32" 3/4" 15/16" Ford -116 F81Z-9C065-AA
HPOP fill plug Viton 1/16" 3/8" 1/2" Granger 1BYB7 100/$7.87 -012
HPOP o-rings Viton90 .078" .468" .624" Grainger 1WHN4 25/$2.77 -906
HPX-over Plugs Ford F4TZ-9N693-A F4TZ-9N693-A
HPX-over Plugs Viton90 .070" 7/16" 9/16" Grainger 1WHN3 25/$2.64 -905
ICP Sensor Viton90 0.072" .414" Grainger 1WHN3 25/$2.64 -905 F4TZ-8255A
IPR - small Viton 1/16" 3/8" 1/2" Granger 1BYB7 100/$7.87 -012
IPR - large Viton 3/32" 5/8" 13/16" Granger 1BYJ4 50/$6.79 -114
Oil fill tube to valve cover Viton 1/8" 1-1/16" 1-5/16" Grainger 1KLD9 100/$5.83 -215
Thermostat housing Viton Grainger F4TZ-8255A
Turbo Pedestal (Large) Viton 0.139" 0.796" 1.074" McMaster-Carr 9464K32 25@$7.18 F4TZ-6N653-B
Turbo Pedestal (Small) Viton 0.139" 0.421" 0.699" McMaster-Carr 9464K544 25@$6.27 -013 F4TZ-6N653-A
Vehicle speed sensor Viton 1/16" 3/4" 7/8" Grainger 1BYC4 50/$6.21 -018
Vibra-loc Fuel lines Viton 1/4" McMaster-Carr 50385K82 $3.27ea F81Z-9C065-AA
Vibra-loc Fuel lines Viton 1/4" DieselOrings.com 4/$9.50 F81Z-9C065-AA
Vibra-loc Fuel lines Viton 5/16" McMaster-Carr 50385K83 $3.37ea F81Z-9C065-AA
Vibra-loc Fuel lines Viton 5/16" DieselOrings.com $2.31 ea F81Z-9C065-AA
Vibra-loc Fuel lines Viton 3/8" McMaster-Carr 50385K84 $3.37 ea F81Z-9C065-AA
Vibra-loc Fuel lines Viton 3/8" DieselOrings.com $2.27 ea F81Z-9C065-AA
Water In Fuel Sensor (Small) Viton 3/32" 3/16" 3/8" Ford -106 F81Z-9C065-AA
Water In Fuel Sensor (Large) Viton 3/32" 5/16" 1/2" Ford -109 F81Z-9C065-AA
Water pump lower pipe seal -141 F81Z-8255-AA
If you start doing this, be very careful when removing the top fuel line from the filter bowl.
I broke mine this morning, Just barely twisted the fitting on the line. Be sure to take out the torx screws instead.
The part that broke on mine is the Fuel pressure return housing or FPR. Rock auto has replacements for about 28$ but Guzzles diesel o-rings has an upgrade Here
http://www.dieselorings.com/index.php?page=details&prod=131&cat=18&group=6
Hope yours goes better than mine...
wouldn't say there known for it, they just have them and no one else does. at least not in the light truck market.
Did you check the turbo pedestal mount, id say its more common from there, but its hard to tell how much oil your talking about with out seeing it.
