You can put a 700R4 in place of a TH350. They both have a 27 spline output shaft in the 4x4 versions and the tailhousings even have the same 4-bolt pattern to them.
And, the NP205 never came behind the 700R4, only the TH350.
Keep believing that, or stop by sometime I have two in the yard.
Easy there skippy
the 700 was mated to....np208, np241, and np205s.
There are 2 different tail shafts
All the 4x4 700R4 tailshafts are the same, 27 spline, male. On the 205, the TH350 it used a male to male coupler sleve. Also, the 208 and 241 are quite similar (they even share the same adapter), so no differences there. And, the NP205 never came behind the 700R4, only the TH350.
But there is a difference in length between the 700 and 350 output shafts.
What time should we come by.I would like to see this mythical factory 700R4/205 combo.The 205's were no longer bein used in 1/2 tons by the time the 700's came along.No such combo.
Really? Mind explaining this one to me? I've only built, oh...a dozen of these.
If you've got a FACTORY 700r4/NP205 combo, I think you might want to alert GM of their folly...Because even they don't know that they built it that way.
Youre right about the 208/241s, though.
Two different tail shafts?? Meaning 2wd and 4wd? Yeah, those are the only two that I've seen. Got another secret from GM? Please, let me know.
Not trying to be an arse, just being real.
I don't want to get in the middle of the 700r4 vs. 4l60. Both are good and can be built to handle more. The differences that I see that make them harder to work with is the electronics and shift cables. For the t-cases and size I would use the 350 and build it, drag race parts, reverse valve body, oversize cooler,.... The trannys are cheap, easy to come by, and easy to build, but it doesn't have overdrive. If you need someone to build any of these trannys I have a friend who is very good with them.
Chris
Contrary to some beliefs, the 700r4 (87 and later) and the 4L60 are nearly the same transmission. There were MINOR upgrades to the insides. Same gear ratios, same torque converters, hard and soft parts all interchange. The only difference was in the planetaries and sun shell. The only "difficult" part of working with them is setting up the TV cable. Obviously, an experienced hand can set them up with ease; however, this is a skill that is usually learned the hard way by the novice mechanic. There are no electronics involved with these transmissions, other than the TCC. It's the 4L60E that is electronically controlled. It has it's own ECM. But, the good thing about that one is that one wouldn't have to worry about setting up/adjusting the TV cable.
Ok,I'll give you the denifit of the doubt since they make some oddball stuff for the mil and aviation ind,but I would like to see a pic of it.
I would think that Jake(croation kid) would know a little about the subject since he's done the 700/205 conv on his M-1008.He was just tryin to contribute to the thread.
FWIW I wont come here and spew crap.
Ive been wrenching and wheeling GMs for 15 years now and have rebuilt around 20 700s for myself and friends
