77 F250 axles
fxracerx
Fayetteville
What type of axle came on the 77 F250s? Im currently working on one that needs a new pinion gear and maybe a new ring gear and I cannot find any info as to what brand this axle is. I also am working on a 72 F250 rear end that might get swapped into the 77 if the gearing matches.
I was thinking that. Well the boss man wants to swap the rear end out of the 72 to the 77 and I get to keep the one out of the 77. Once I rebuild it Im thinking about putting it on my silverado. I know I will need to fab up the shock mounts and probably do some work to the brakes. Would it work on my silverado and would I be able to get some 8 lug hub to fit on my truck?
swap the front axle
I would swap the front axle but I only have a 2wd truck and I would have to fab the whole front suspension. I can get ahold of a complete front end on a 72 f250. What rear end is on my 09 silverado I cant find anything on it also.
