ghost
- May 25, 2006
- Hartsville/Camden,SC
So I broke a rotor in Harlan The caliper spring and H key kicked out and the caliper slapped up and down and bent the caliper hanger. I believe this is the rotor I need. It's been so long since this thing was apart I can't remember. Isn't the rotor and hub separate?
DuraGo BR5445 Front Vented Disc Brake Rotor
Doesn't give the stud size and I've seen that there are two rotors one with 9/16 studs. Since my brake caliper hanger is bent I'm looking to replace it too. I'm finding conflicting info. One diagram says it's 2B292 A thread on Pirate says its 1978-1979 Ford Dana 60 Front Caliper Bracket Right Hand Passengers Side 620090 R. Also can anyone confirm that way it is supposed to go together? H bracket on bottom with spring on top of H bracket? Will add a few pictures of the damage.
