Finally found/fixed all vacuum leaks except for the break booster. When i suck on vacuum hose going to booster, no vacuum at all. Right now the vacuum port is capped off so engine will run properly and I have manual brakes. Anyway to check if the problem is the brake booster or the valve the line hooks too? Anyway to repair the brake booster if it is the problem? Anyone have a spare brake booster they want to get rid of? (need a radiator too)
Thanks in advance,
Tim
Thanks in advance,
Tim
