81 toyota steering ques.
krehel24
<- and it begins!!!......
Locust NC
I have a 1981 toyota, I have a 2" shackle in the rear and just added a 3" leaf spring in the front(stupedlift :rolleyes: ) with the stock shackle. Would like to know if i need to change the steering arm? I know i have seen a lot of lifted yota's with the S shaped steering arm.
If your wheeling hard, and want it to flex well and not brake, you'll need to some sort of crossover. Marlincrawler.com
Procomp make a beefy link that you are talking about that has an S bend. I used it for quite a while when I had my toy. Sells for about 60-70 bucks.
81 toyota
i have a 81 toyota and i added 2 more leafs in the fornt and a two inch block and now the steering is hitting the leaf springs is there any suggestions on how to fix this thanks
Yea, get rid of the block before you kill yourself. Lift blocks on the front are extremely dangerous. Do it right. You need new springs and a crossover steering like was mentioned above. You'll need a steering box out of an IFS truck. The easiest way to do it is to buy a kit from someone like trail gear or the like. But you absolutely need to get rid of that front block!
my budy has a drop drang link that I'm sure he would let go for cheap. I will ask him what he wants for it and then let you know.
