rightwinged
- May 7, 2010
- new bern
In process of doing a ground up resto of my k-5. Ran into a snag with the pass. side window motor. The window wouldnt go up or down, so i figured bad motor. Replace motor, nothing. Checked voltage at the motor, 12 volts. Replaced motor a 3rd time, same story. The door is out of the truck, but everything is wired up how it should, and like i said, it is getting power to the motor. The locks work fine, just no windows. replaced the 30a fuse for master window, nothing. Am i missing something? if the motor is getting power, it should work. doubt 3 motors are bad, since 2 of them were brand new, not remanfactured. Any relays or fuses im missing?
