yotawheelin
- Aug 26, 2009
- rock hill
ok i bought a 88 sami this past weekend. guy says he had the head rebuilt a few miles ago, new pistons and valves i believe along with the head all cleaned up. then he put a weber carb on it with the k&n lookin filter on it and took out a lot of emmissions and capped off a lot of vacume lines and took off a lot of vacume hoses. now it smokes blueish whiteish smoke when cold and when first acclerate and when you shift gears. also noticed that on the plugs it looked to be runnin rich the plugs where black black. then on numbers 3 and 4 the plugs where white so i checked the oil cap sure enough it showed coolant mixed with the oil on the cap. but on the dipstick the oil didnt looks bad at all. driving down the roadthe sami drives fine but after it heats up to normal temp it will start to slowly rise in temp and overheat. i called the guy and he said he tried bars head gasket sealer but HE stuck it in with the radiator fluid which it said not to do. it said flush system out before use. so here is what i have done, i flushed the entire system with hose, i took off water pump inspected it cleaned it did same with all hoses related to cooling system and took out the radiator itself cleaned it, as well as replaced t-stat. only thing i did not clean was the heater core. everywhere i found cloggs and chunks of sealant stuck everywhere in chunks. i checked system with pressure tester soon as i cranked it (motor was warm) pressure went to 17psi. killed it and flushed system again tried head gasket sealer myself the right way and changedthe oil, and still motor does the same thing it warms up then starts to slowly overheat. pressure bulids up and it spits the coolant into the overflow. but im not seeing the bulid up of coolant on the oil cap hardly at all anymore.
what do i need to do now? could a clogged heater core or not free flowing cooling system cause this or is it for certain a cracked head or blown head gasket causeing all this? also could a misplaced vacume hose or missing vacume hose or emmission system be a problem? cause i would put it past this guy to have done something wrong when takin everything out.
thanks for any help i went broke almost buying the sami now i just want to enjoy it.
