9" third member question
chasespop
Clinton
If a small bearing housing has a third member set up for 31 spline, then the size of the carrier bearings have been reduced to the larger carrier right?
I have an opportunity to purchase a chunk but it came out of a small bearing housing, mine is the large bearing housing.
I would like to keep the larger carrier bearing in the rig for obvious strength reasons.
A little clarification
Thanks
The carrier bearings do come in different sizes, ie: 3.250, 3.060, 2.891, etc. The bearing ID on the carrier/spool/locker is the same for all, its the bearing OD that differs. So, yes, you could run a carrier from a small bearing housing in a big bearing housing granted you pop the small bearings off and replace them with correct size.
