90 Bronco II clutch questions? Whats your clutch pedal rod look like?
gmcjimmy88
Fayetteville
I got a friend who has a 90 Bronco II. We put a new clutch and slave cylinder in the truck. Went back later to bleed the system but the clutch pedal looks to be bent/broken. The rod from the pedal is no longer contected to the firewall and it is bent almost 90 degrees. Is this bend normal? How does this connect? Is if fixable or does he need to replace it? Thanks for the help in advance.
