My 1995 AX15 transmission recently crapped out on me, i think its stuck in 2 gears and the front main bearing is shot. The engine tranny transfer where swapped out of a 1995 Cherokee fyi.
So heres the thing, i found great deal on an ax15 from a fellow nc4x4 member (criminalxj). When i bought it i had not done much research on the different ax15s cause i thought an ax15 was an ax15. When i bought it he said it was out of a 92 or 93 and mines a 95 so i didnt think much of it. So i get it home and drop the old one and go to start swappin parts and first i see the bell housings are different, no big deal right. Start to swap them then i notice the input shafts are different sizes CRAP. First thing that came to my mind was swappin the shafts out in the trannys, then i thought why not get another pilot bearing. So we go to THoff forgeting to bring the old bearing we get a pilot bearing for a 92 cherokee awesome right. Get home and the outer diameters are different so the new one (for the 92) will not fit into the crank. This is the point im at now.
So my chocies are swap shaft(really hard), Find a pilot bearing that fits(what i would like to do), Mill the outer sleeve which is separate from the bearing so it will fit into the crank(friend has the equipment).
Anyone done this or had this problem? Any help would be appreciated.
