dmoore714
- Jun 6, 2009
- Americus, GA
I've had this problem twice with my '92 Cherokee. I turn the key, the lights and accessories come on just fine, but the starter does absolutely nothing. Both times I got around it by putting the jeep in nuetral and letting it roll a little bit. Then put it back in park and it starts. When it does start, it turns over just fine.
I'm guessing its a neutral safety switch. Or maybe a bad solenoid on the starter. Any thoughts on either of those? And is there anything else I should check out while I'm at it?
If it is the neutral safety switch... should I replace it or just bypass it?
