Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
anyone know if I can put a 94 4l60e in my truck? Got a smokin deal offered to me on a rebuilt one just need to know if it'll work asap por favor
chevyz71man
10-04-2007, 05:57 PM
The valvebody in 95 is different. You could switch the valve bodys though. or maybe just the harness. I have a 96-99 60e in mine.
I know the computers are both 7427's in 94 and 95.. not sure if it matters or not.
Fast305
10-08-2007, 09:38 PM
The difference is in the valve body. In trucks for 1995 they added Pulse Width Modulation to the Torque converter clutch. PWM TCC. Doing this added an additional solenoid to the valve body and a 13th pin to the wiring. Personally speaking PWM TCC is a pain in the rear. PWM TCC also changed the programming in the Memcal. All you have to do is find the same calibration for a 1995 truck that had the same engine, gearing, etc.
these are camero's
these are camaro's
the cases are valve bodies are different and the resistance on the solenoids is different, so it won't work without pcm reprogramming
Yes, please let me know what you find out. I am still about a week or so away from taking it in for the tranny as I need to replace that broken motor mount, but if I could get a definitive answer on what the solution is, I'd be willing to try to do it myself.Yea I've had Troy rebuild the 700r4 in Kevins K5 for me, he's a cool guy to deal with.
As far as the conversion, I guess I'm bout to find out cause I bought the 94. I'm just gonna set both trannys side by side pop open the valve bodies and see what's different and try and swap it over, If I get it to work I'll let you know, might save you some $$ to do it yourself, although like I said Troy seems to know his stuff.
