Hurley
WTFab
- Feb 22, 2008
- Statesville
So I have just purchased a 95 cummins 2wd with auto trans. Truck has 187k miles, I've no clue on the history of the trans - whether it is original or not. Currently the trans fluid is at an acceptable level and quality. I've only driven it about ~60 miles.
The problem is the inability of the thing to shift to overdrive and then stay.
Shifting into OD generally takes a nearly full throttle application, resulting in a shift point around 2300rpms. once it's in OD, it will drop back to 3rd - regardless of throttle position, road grade, engine load, vehicle speed. Then it will shift back to OD, and the cycle will repeat soemtimes as frequent as every 5 seconds, and sometimes I can travel a mile before it happens.
What is wrong?
- Joey
What is wrong?
- Joey
